Spanky,
The ELK java app for the ethernet module does not work in IE7. I get runtime errors. Also, it does not work under Vista, which I assume is IE7.
Please advise if you are aware of the issue and if any resolution is in sight.
If anyone else is having the same problem or has a fix please advise.
thanks
thanks
