All:
I have recently finished installing an Elk M1G, primarily for security. However, I chose the M1G because of the promise of automation capabilities, specifically lighting control. I am quite satisfied with the system so far, and am now deliberating which technology to use for lighting control. I am looking at three possibilities, all with varying degrees of support from Elk on the M1G: UPB, Z-wave, and Insteon.
I have been doing quite a bit of on-line research on these three (and others that have dropped off the short-list). Many thanks to you all on this forum, as I have learned a lot from the posts here. I have also culled some data from the Elk web-site equipment manuals. I have started a small spreadsheet comparing UPB, Z-wave, and Insteon with regards to how they interact with the Elk M1G. I would appreciate any feedback, corrections, or additional information that anyone can provide.
I've attempted to attach a copy of the spreadsheet (Excel converted to html). I will add any inputs into the sheet and include any other pertinent comparison data and re-post, keeping this current for others benefit. I am new to the forum, so please advise me if there is a better way to work with you all and / or post this information. I really am mostly interested in how these technologies interact with the M1G, but would be open to pertinent information for "hybrid" systems. (Example: M1G Elk coupled with Other automation controller either via serial or digital IO)
Looking forward to hearing from you all:
Best Regards,
Rod
Best Regards,
Rod
