Elk Arm Beep
gcimmino
Occasionally, when pressing the Exit key to arm away, the keypad will "boop", that is an error like beep sound. I have to press the Exit key a second time to arm the system.
Note that the panel is "Ready" in all cases prior to arming, no violations, nor troubles displayed, and Single keypress quick arming is enabled in the Area.
The panel is 4.3.10.
What is this sound and why is it intermittent?
flyguy
Was wondering about this myself as my system will sometimes make that error in the sound when the chime goes off (when opening a door or window). System works fine, otherwise. Dunno the solution though.
