Elk - Can I trigger panic alarm in with a Rule?
Greets,
So I've got a set of rules using a counter and output timer so that if KeyFob button 4 is activated 3 or more times within a 15 second window a rule will activate...
Is there a way to trigger a panic alarm with a rule? (I'm not seeing any way)
Any help would be appreciated.
carry15+1
None that I know of at this time - you can do a panic from a keypad f-key. I'm still using ElkRP 1.6.6 though and perhaps a newer version supports this.
I'll see if anyone else has a suggestion, but it looks like the only way may be to run a loop thru my output relay board and call that a "24 hr" input zone. Then use the rule to open the relay. Seems a bit "kludgy" however.
