When my house was built, they had put in a external air intake with a power damper to close it off. The setup had a honeywell controller separate from the thermostat that would, on schedule, open up the damper and run just the fan to pull in outside fresh air.
When the installer put in my heat pump and my Aprilaire 8870, they left that honeywell controller disconnected. Now, with many days having the outside air a good bit cooler than inside but not enough to really want to run the A/C, I'd like to get that exterior air intake working agin. I'm not sure that the 8870 can do it.
What I want is a mode I can put the thermostat in to where it opens up the damper and runs the fan for a set amount of time. I want this to be controllable from the Elk too. Or, I guess I could hook thermostat directly up to CQC (if supported) to get functionality I want that way if Elk doesn't support it.
Can the 8870 do this? If not, would the new 8800? Or, is there a better thermostat option that works with either the ELK directly or with CQC?
Thanks for any suggestions!
