KP1: Internal Temperature Sensor
KP2: NONE
KP1: Large, Easy to Read Characters LCD Display Back lighted with Adjustable Intensity
KP2: Blue/white Backlighted Hi-Contrast LCD Display
KP1: Removable Hinged Door / Surface Mount
KP2: Surface mounts to a standard 1 or 2 gang electrical box Optional recess ’flush’ mount kit available (ELK-M1BBK2)
KP1: Programmable Function Keys (6)
KP2: Four (4) Programmable Function Keys
KP1: Unique Menu Navigation/Direction Keys
KP2: Unique Menu Navigation/Direction Keys
KP1: Operates on 4-Wires (M1 Data Bus)
KP2: Operates from the M1/EZ8 ’RS-485’ Data Bus
KP1: Built-in Speaker with Adjustable Beep Tone and Volume
KP2: Built-in Piezo Sounder with adjustable pitch
KP1: Accepts Plug-in Proximity Card Reader (Optional)
KP2: Accepts "External" 26 bit Weigand Prox Reader (Optional)
KP1: Input for 1 Supervised Zone
KP2: Input for 1 Supervised Zone
KP1: One Programmable Voltage Output
KP2: One Programmable "Switched Positive" Voltage Output
KP1: Exit, Stay, Chime, and Bypass Keys
KP2: Exit, Stay, Chime, and Bypass Keys
KP1: Input Connection: 6 Pin Plug-in "Flying Lead" Connector Included
KP2: Connection: 6 Pin Plug-in "Flying Lead" Connector (Included)
KP1: Proximity Connection: 5 Pin Plug-in "Flying Lead" Connector (optional ELK-WO35A required for external proximity reader)
KP2: Not specified
KP1: Color: Glacier White
KP2: Color: White
KP1: Operating Voltage: 13.8 VDC
KP2: Operating Voltage: 13.8 VDC
KP1: Current Draw: 40 - 50 mA Idle (low back light level, sounder silent) 160 mA Fully Active (max. back light & sounder active)
KP2: Current Draw: 40 - 50 mA Idle (low back light level, sounder silent) 160 mA Fully Active (max. back light & sounder active)
KP1: Size: 6.875" W x 5.25" H x 1.375 D
KP2: Size: 4.658" W x 5.5" H x .95" D (.375" D with recess mount)
