ELK install take one. In my defence I bought this alarm as a replacement for a GE concord system that I gave to my brother. I wanted to get something installed fast
Things done right
*Ran 2" conduit up to attic for future proofing
*Pulled and left strings in all the tubes
*Installed ample plywood to mount additional devices or cans
*Secured the wires exiting the box inside conduit so that you can just come over to the panel and cut everything.
Things I am redoing/did wrong
*Box way too small. I thought I could use the regular box but I already decided i needed a relay module to control my sprinklers and garage door. I have a 28" box now. I terminate all my audio and video in a differnt closet so I think this is big enough but if I were to have video termnations here too I would have gotten two giant boxes.
*Too small conduit from can to junction. I knew I was going to redo this so this was not a 'mistake'. I had extra 3/4" condut and wanted to play late one night. My plan now is to drill the box out for 2" conduit and take that to my junction box
*Didnt buy the the rails for the cards rails. I am not sure if I will use rails for the internet module but having the modules give me a choice. If you are using the smaller box the rails keep everything compact
*using 4 conduit wire for the keypads and the wireless module. Unless you get one of the expansion modules you only can run two home runs off the bus. When planning make sure you check this part of the manual out. they recommend using cat5 for many of those runs and using the extra pairs to double back. Other solutions would be to get the bus expanders, either the cat5 plug in style or the 'old work' stye. check this part of the manual out as other alarms I have installed allowed you to homerun everything to the bus
*Bring power into bottom of the box. much more secure and if you are going to expand the system you are likely to need additional power wall warts anyway.
*Extend bus line to the attic. I wired 4 wire to upstairs keypad. When I rewire with cat5 I will also extend that up into the attic in the event I want to put an expansion module up there. I was thinking of adding some upstairs sensors to turn HVAC when my wife opens the frigging windows.
Things done right
