Elk keypad light failure
Xpendable
So all of the blue LED's in my Elk M1G keypad (was the newer style in 2010) have burned out one by one over the last 4 years.  The LCD backlight is fine, but the blue LED's illuminating the keys have all burned out over time.  Some of them flickered for awhile on their way out.  The green / red status LED is still fine.  Even the blue led behind the chime button has now failed.  Anyone else had this problem?  I haven't yet taken the keypad apart to see what kind of LED's these are.  I'm going to guess they are surface mounts, maybe 0805 size?  I have a hot air reworking machine so I could pull these off and solder on replacements.  It's unusual that the LED's would all seem to fail like this.  They should be lasting a lot longer than that, unless they are being over-volted or the solder joints are bad.  Again, just wondering if anyone has had this problem.
Give them a call.  I would assume they would want to know this and they might take care of you etc.
