Hello,
This is my first post and I'm a new user to the forum.
I've installed an ELK M1 Gold control panel in my new home and I am working to get the system operational to be monitored by Alarm Relay (most likely). I have an Ademco 7845iGSM cellular communicator from my older home that I would like to incorporate into the system. Below are my questions:
1. I'd like to have both internet and cellular monitoring. Would you recommend that I use cellular communication as primary and Internet as backup or vice versa?
2. How do I connect the 7845iGSM to the M1? I found a Honeywell Tech Note bulletin that states "The 7845GSMR / 7845i-GSM will work in Zone mode with any manufacturer's security panel. To use the cellular communicator on these products you will need to determine if your device will be providing a postive voltage output, negative/pull-to-ground, or a contact closure (Normal Open/Normal Closed). Your next step will be to provide the 7845GSMR/7845i-GSM zone inputs for the correct trigger type: V+, V-, or EOLR." Given this explanation, any detailed guidance you can provide on how to wire the 7845iGSM to the M1 would be greatly appreciated.
3. Internet monitoring - It is not clear to me if I can connect to Alarm Relay with just the ELM-M1XEP ethernet module or if I also need a broadband internet model? I have a call into Alarm Relay but wondering if anyone can answer this question for me?
Thank you in advance for any assistance you can provide re: these questions.
