RonTJohnson
I purchased the following:
M1 Gold kit
Data Bus Hub
two additional keypads
three Zone expanders
Ethernet port interface
Lighting, Thermostat int & serial exp.
My alarm zone wiring is home run to a different location than my main equipment closet (long story, see below). There are two cat5e cables running from the alarm zone home location to the equipment closet. My plan is to install the ELK M1 platform in the equipment closet along with the eithernet port interface and the serial expander. I will then Install the Hub at the Alarm Zone home location along with the Zone expanders. I plan to connect the Hub to the M1 using 2 pairs of one of the cat5e cables that return to the equipment closet. This means that I will not be using the first 16 zones on the main board for my input zones (except that i might utilize anther pair of the cat5e cable for connecting to zone 16 for smoke detectors).
Does anyone see a problem with this setup?
For those interested in sub-contract screwups:
Installer was supposed to look at my home that was being remodeled and give me a bid. For some reason he decided to send a wiring crew and geve a bid latter. My contractor thought i hired them to wire for an alarm system so he let them do their job. I showed up on day two and to my astonishment, most of the wire was installed and to a location that was not my equipment closet. (Its about 20 feet away). I was not happy for two reasons, 1) i didn't hire anyone to do anything yet, and 2) the wiring was to the wrong location. I thought that all was not lost so if i had them run two cat5e cables from the alarm home location to the equipment closet which they did. I have not yet paid for anything and i refuse to pay until i get a diagram of where the wires are which is something i was promissed. Can you beleive this?
M1 Gold kit
Data Bus Hub
