SpaceCowboy
Hey Cocooners,
Wondering if anyone is monitoring the humidity in their home via an Elk panel? Since it could use an analog sensor I wondered if anyone was doing that, and with what/which sensor.
In the past I think a few people suggested a 1-wire option but I don't believe that to be the easiest route (since you need to run a 1-wire "hub" somewhere?) and needed some software.
I'm thinking about just a plain variable voltage output sensor I can plug right into a Elk zone and write some rules around it.
Thoughts?
Thoughts?
