Elk M1 PIR programming
I am trying to program the NX 481 wireles PIR. I mounted according to directions and it lights up when I move. I then attempt to program it and the instruction manual is worthless. What settings in RP should i use? ANy help would be apreciated.
Digger
Program it as an Interior Zone (Type 04) and then in the wireless setup enable the zone and select normal supervision. You do not need to select either of the 2 options if I remember correctly.
Remember that the detector waits 3 minutes or so between transmissions to conserve the batteries (they last a few years this way typically).
