jon102034050
Hey all, I've got a pretty standard Elk M1 Gold setup, nothing too fancy with 4 motions, 6 doors, 4 speakers, and 2 keypads all wired. I'm using AlarmRelay for internet monitoring, and all is going well so far, but I need to address the issue of battery backup on my network components (router, modem, m1xep).
I found the following thread after searching:
http://cocoontech.com/forums/topic/22538-elk-m1-motion-sensor-low-voltage/
But it doesn't quite fit my situation. The router, modem, and m1xep are all 12v, and use 600mA, 750mA, 300mA respectively. But I've also got a Commscope amplifier that is amplifying the cable feed that is plugged into the wall and is 15v using 500mA. As I understand it, I'm unable to use the p212s now because that doesn't run at 12v (also it consumes more than 2 amps...)
How are others addressing this? I'm still pretty new to this stuff, so any and all advice is welcome! Thanks!
Also, I did some testing both with and without the amplifier on my cable feed, and I consistently got 8-12mbps faster with my wired internet connection (using the amplifier), so I think the powered amplifier is a necessity.
