I just installed an M1G this weekend, and signed up for NextAlarm service. Based on the reports of others, and the fact that I'm able to use an uncompressed (g711) format with my VoIP provider (VoicePulse), I had hoped that I'd be able to connect via phone until some options open up for internet monitoring (I also got the ethernet adapter).
The set-up procedure for Nextalarm has you trigger an alarm, then check their internet based activity log to confirm that the communication was successful. The alarm did register. In fact, it registered 14 times. But I'm getting a "commun error" (or something to that effect) on the keypad. Since it appeared to report the alarm multiple times, is it a fair assumption that although Nextalarm is getting the alarm fine, for whatever reason the M1 is not reading the kissoff (and therefore trying again)? Any suggestions on resolving this? I did notice that there was some noise while using the phone control feature of the M1, which made me wonder if I had some cabling issues, but regular phone calls (which have to route through the M1) sound fine. Is poor sound quality for the phone interface normal?
Thanks!
Thanks!
