alarmperson
My ELK-M1 has been up and running for several years with 4, ELK-M1KPNAV keypads with no issues. My original system came with an ELK-M1KP that I never installed. So the other day I thought I would install the ELK-M1KP as a 5th keypad in the basement area where my ELK-M1 is mounted. That's when my troubles began.
All of the keypads are installed as a home run back to the ELK-M1 via the ELK-M1DBH using CAT 6 cabling. As I stated before all 4 of the ELK-M1KPNAV worked for years with no problems. However when I install the M1KP, also as a home run one of the M1KPNAV appears to lose its bootware setting and firmware setting as well does the M1KP after you run the enrollment process.
No matter what configuration I use on the M1DBH when using all 5 keypads its always the same results, where the M1KP and 1 of the M1KPNAV (always the same keypad) lose what appears to be their bootware and firmware when viewing the Enroll/update control devices screen.
However after enrolling everything one at time in many different configurations I have determined that only one of the M1KPNAV causes this error. When using just the other 3 along with the M1KP everything works fine but as soon as you add this one particular M1KPNAV to the system the error occurs. It seems that this one M1KPNAV just does not like playing with the M1KP because it works fine with the other three M1KPNAV's in a M1KPNAV stand alone setting.
Could there be something wrong with this one particular M1KPNAV? It works fine in the 4 keypad setting using just the M1KPNAV's.
