I am just setting up my M1G with the M1XEP. I set it up temporally and got the keypad enrolled and the M1XEP online through the RP software.
I then modified the closet and re hooked up the M1G and now having problems.
I think the keypad is not enrolled and it will not allow me to enter the program mode. I select the ELK button, press 9 for program, and it asks for the pin authorization code. I enter 172839, and it doesn't do anything and eventually will go back to the main screen. The screen reads Not Ready Area 1, Output 2 trouble ( no siren connected yet) Ethernet trouble, and common not armed
Question: Can I re enroll the keypad? Do I also need termination jumper on back of keypad and M1G J3 if I only have one keypad? I have tried it both ways
And to really complicate matters I can't get the M1XEP on line. I have static address of 192.168.0.251. and opened the router port 2601. I ran the diagnostic and this is what it came up with:
Name:
MAC Addr: 00-40-9D-B6-60-24
IP Addr: 192.168.0.251
Secure Port: 2601
M1XEP serial port OK: No
M1XEP has initialized: No
DHCP: No
Subnet: 255.255.255.0
Gateway: 192.168.0.1
Pri DNS: 0.0.0.0
Sec DNS: 0.0.0.0
Non-secure Port: 0
AMX Beacon: No
Email Server: (IP)
Email Port: 25
Email From Addr:
Email Username:
Email POP before SMTP: No
DDNS Server: (IP)
DDNS Username:
DDNS Hostname:
DDNS Email To:
DDNS Email on Change: No
SNTP Server: (IP)
SNTP Update Time: 00:00
SNTP Time Zone: GMT-13.00
SNTP Email on Errors: No
Bootware Version: 2.0.4
Application Version: 2.0.42
Problems:
There may be a problem with serial communication between the M1XEP and the control. Check the serial cable connections and the control's serial port baud rate. This error can also occur if the M1XEP's firmware is older than version 1.3.24.
The M1XEP did not properly synchronize with the control. It could be still initializing. Wait several seconds, then click the BACK button and try again. If that doesn't help, reboot the M1XEP and try this again. If the problem persists, check the serial cable connections and the control's serial port baud rate.
The M1XEP's Primary DNS is invalid. That may prevent the M1XEP from making out-going connections.
Results of the test of DNS address
00:02:37 DHCPINFORM enter
00:02:37 DHCPINFORM sock=00000028
00:02:37 Open_Socks: 12 = 01
00:02:37 DHCPINFORM sendto returned: 00000100
00:02:39 DHCPINFORM recvfrom returned: FFFFFFFF, RcvTimer=0
00:02:39 DHCPINFORM getErrno returned: 00000000
00:02:39 Close_Socks: 12 = 00
00:02:39 DHCPINFORM done
00:02:39 DHCPINFORM ReturnCode=02
Could this be one of the problems?
( I changed the ethernet cable, but don't have a replacement ribbon cable) Also I tried to reboot the M1XEP using the diagnostic.
Thanks for your help
Name:
Secure Port: 2601
DHCP: No
Pri DNS: 0.0.0.0
Sec DNS: 0.0.0.0
Non-secure Port: 0
AMX Beacon: No
Email Server: (IP)
Email Port: 25
Email From Addr:
Email Username:
DDNS Server: (IP)
DDNS Username:
DDNS Hostname:
DDNS Email To:
SNTP Server: (IP)
Problems:
