elk rules
jduncc
I'm trying to write a rule that will turn on and off a sequence of lights. What is weird is that it is only executing the first THEN statement, and it's not firing the rest. Any ideas?
Thanks!
electron
Administrator
Staff member
Are you using the 'test' button? I believe there is a known issue which causes this kind of behavior when using that button. If you are using the button, try triggering the rule by having it monitor a certain output, then write a rule which will turn on the output (so you can use the test button).
jduncc
Yes, that is what I was trying to do. When I run the task from the keypad it works perfectly.
Thanks!!
Hopefully elk will fix that in the next release because the test button makes it really easy to make sure it will do what you want.
Thanks again.
