I think for as long as the m1/m1g has been in production I've been seeing conversations about temperature sensing options for the units.
Conversations about how to make the sensors looks better, and recently an excellent analysis of how elk sensors communicate.
From my [largely electronically-challenged] analysis, I think I have the three temperature sensing options available:
1) Elk temperature sensors. Pros are that it works. Cons are that they are relatively expensive. However, it was recently noted that they communicate via serial, which in my uneducated analysis would indicate each sensor has a built-in A/D converter using 12 bits, which provides excellent resolution. The Elk input must be set to type 33 to read them.
2) LM35+opamp. Pros would be the relatively low cost. Cons being you have to assemble them. Elk panel would be set to type 34(?) to read them.
3) DS 1-wire sensors. Pros are that they are extremely inexpensive. Cons, you have to interface the sensors to the Elk panel. Perhaps the Midon temp08? It has been stated that Elk will be introducing a 1-wire interface.
For my own purposes, I think that option #1 is least attractive due to cost. I am in the final stages of finishing my new house, and I am looking to monitor far too many temperatures to make the Elk sensors economically feasible. I want to monitor temperature in each room, temperature of each radiant zone supply/return (3 zones), temperature of the radiant slab in each bathroom, temperature of the hot water heater and temperature of the hot water recirculating line. Eventually I would like to monitor the temperature of each radiant /loop/ (25 loops), although this is largely for my own amusement.
Options 2 & 3 are about equally attractive, although the rumor of an impending 1-wire driver is exciting.
My question at this point is about polling each type of sensor. I would like to know if there are any advantages to say, a digital output versus analog. Will polling a certain type eat up cpu? Or will one type be a problem to constantly update and make sure the rooms are maintaining temperature?
TIA,
Tim
TIA,
Tim
