simonmason
I am in the process of replacing an ELO touchscreen in my kitchen. When I purchased the first unit the touchscreen glass was stuck to the screen so I just put it in the wall. It failed recently and I purchased a replacement on eBay. The new unit came with the touchscreen glass sitting on the screen - but not mounted. I called ELO and through their repair distributor ordered what I thought was double-sided foam to mount the glass. When it came it was only the same single-sided foam that was mounted to the screen originally, providing a soft cushion for the touch glass to sit on. I then took a closer look at the older screen and it looks like they originally put double-sided tape on the screen, and then used the single-sided foam tape to mount the touch glass to the tape. Has anyone had any experience with this? I am now starting to look for the double-sided tape they used? Thanks.
