I did not see this in the tutorials, but maybe it can be moved there?
This is a very quick version of the local dimming mod. As these switches are available for $5-6 (including optional slave switch), this a very inexpensive way bring x-10 with local dimming to your entire household, upgrading to better switches as the budget (wife) allow. I'm slowly moving to Switchlinc/Switchlinc II swiches throughout.
This elimated the biggest WAF for me--not being able to dim from the main switch where I installed basic x-10 switches (I have 10 of these around the house).
1. Pry the cover off of the wall switch pressing the four corner tabs.
(by Albert Tejera).
2. Locate the 47uF electrolytic capacitor, take some needle nose pliers and gently squeeze the end of the capacitor. Since an electrolytic is made from a pair of foils separated by a thin dielectric and then rolled together, squeezing the end of the can creates the desired short internally and effortlessly without breaking or pulling out any pins.
(I'll add a photo when I mod my next switch)
3. Reassemble.
4. You now have local dimming by just pressing and holding the light switch.
Can anyone speak on any possible issues that may occur from shorting this capacitor? I have had no problems so far.
Found on http://www.geocities.com/ido_bartana/, based on a description from Hans Attersjo.
(by Albert Tejera).
3. Reassemble.
