I boght some NX-470 keyfobs to use with my M1G, which has a wireless expansion card. I had no problems enrolling some wireless motino sensors, but the installation manual isn't very on keyfobs. I assume you go through the same steps as with a motion sensor? The instructions say to press the "tamper or enroll" button, but when I get to that step of the set-up, the voice appends the instruction with "four", so I assume the correct button on the keyfob is button four? Regardless, no matter which button I press on the keyfob, nothing ever happens. What am I missing?
Edit: ONE of the FOBs I have had the TX number with it, so I was able to manually set it up using that in ElkRP. But I still don't understand why the normal "learn" method didn't work, and until I figure that out, I won't be able to get the other ones enrolled.
