I will try to explain my issue as best I can.
I have an Elk M1Gold, and on the main floor I have the following zones:
1)Front Door - Burgalary Entry/Exit1
2)Garage Door - Buglary Entry/Exit1
3)Deck Door - Buglary Entry/Exit 1
4)Man Door (off Garage) - Burglary Entry/Exit 2
5)Great Room - Buglary Interior Follower
6)Stairway - Buglary INterior Follower
I have zones 5/6 setup this way, as you enter the front door the motion from the stairs picks you up, and then as you move to the keypad (which is about 1/2 way to between front/garage door) the great room sensor picks you up.
Normally we go out the garage, and hit the exit button and the system arms fine. We usually also return through the garage, and then deactivate the alarm and all is fine.
When we leave through the garage, and return through the front door the alarm goes off.
Here is the log file
1338 Area 1 Exit Error
1003 Buglar Alarm Any Area (Stairway Zone)
How can i fix this?
Thanks in advance
Jeff T
How can i fix this?
Thanks in advance
Jeff T
