Ge sensors monitored by Homeseer?
Rustytek
I was wondering if it was possible to monitor the ge sensors by using something like the new ELK g1rfxg2 sensor to read them. I would hate to install a security system and run the wires for keypads/etc. it I could just read the wireless sensors into homeseer (smoke detectors, window/door recessed contacts, water sensors).
If you do not have a security system yet you can use the Visonic (NextAlarm, SecureLink) sensors with the RFXCOM receiver and the ACRF plug-in. It is expected that in about 2 months the 315MHz Visonic receiver for the US will also be available at www.cheapertronics.com
ano
GE makes a Quickbridge device that can monitor 8 wireless GE sensors, then it gives you outputs that a PC can monitor with a digital input card. I do that. I have a security system with 48 zones, but I wanted a few extra that didn't need to be used for security and they could go right to Homeseer.
Spanky
The ELK M1XRFG2's data bus output requires the M1 request its data after a RF packet is received. Complex protocol to do it, but a good idea to have an ASCII streaming output on received data.
