Generic lighting scene question
I'm trying to understand this scene control better. Given the following
switch 1, switch 2, switch 3
scene 1 - switch 1 on 75%, switch 2 on 75%
scene 2 - switch 2 on 25%, switch 3 on 25%
I'm not sure if this next part veries by scene controller or not but here goes.
If I press the scene 1 button. an indicator light on the scene 1 control lights up, switch 1 comes on 75% and switch 2 comes on at 75%
If I press the scene 1 button again, the indicator light goes off, and both switches go off.
If I press the scene 2 button, an indicator light on the scene 1 control goes off, and scene 2 goes on, switch one goes off, switch 2 dims to 25% and switch 3 comes on to 25%
Is this correct?
Secondly, is there a way to control the scene 2 control indicator light, for example, my scene 2 is a bedtime scene, If I press it, the lights dim, and then via some computer controller, they dim again, then finally turn off. When I turn everything off, can it also turn off the indicator light on the scene controller? or does this vary by computer program and by scene controller?
rocco
Is this correct?
Hi, Calypso:
When you activate scene 2, switch one will NOT go off. Switch one is not a part of scene 2 (as you defined it above), and activating one scene does not deactivate all other scenes. Only lights that are part of that newly-activated scene should be affected.
A lot depends on what technology you are using, but I believe that the above applies to most all of them.
Herdfan
Yes it does. My Lutron system as 3 distinct logic modes for "Scene" control.
Scene Logic - Keypad button is lit as long as ALL the programmed lights are on to set levels.
Room Logic - Keypad button is lit as long as ANY programmed lights are ON at ANY level
Path Logic - Keypad button is lit as long as ALL programmed lights are ON at ANY level. (Worthless if you ask me.)
So given your scenario:
In "Scene Logic", the Scene 1 indicator would go off, but Switch 1 would have stayed on.
In "Room Logic" the Scene 1 indicator would have stayed on because at least one of its devices (Switches 1&2) were ON.
Now you could have programmed Switch 1 to go to 0% in either logic, but even if you did, using "Room Logic", the Scene 1 indicator would have remained lit as Switch 2 was still ON.
