upstatemike
I have 2 plugs in a kitchen that are fed separately from the basement so I am putting a GFCI in each location. They do not feed any downstream plugs but one feeds power to the range hood and the other feeds the light switches.
Should these "non-plug" downstream devices be connected to the protected side of the GFCI or is that feed-through only for downstream outlets? I'm thinking they should stay on the unprotected side since they are not required to be GFCI protected according to local code.
