jcrack_corn
Interesting problem....I did have my PLC hooked to mainlobby server but response times were horrible for turning on/off lights (at LEAST 3-5 seconds, sometimes 10 after mainlobby button pushed before light reacted)...complete garbage.
So, I went the proper route and hooked PLC directly to elk w/ serial expander (my #1 priority is function and realiablity without use of the mainlobby server)....and thinks are now awesome....the elk registered all insteon devices with no issues (just did the tap method, instead of powerhome)....and commands are literally instant (not only from elk but from mainlobby sending the elk a command!) could not be happier, it functions as if it is hard-wired.
Problem is that i get about 1 random light turning on (never off) per day....it happens all across the board, all switches affected at some time. This is definitely as a result of PLC being hooked to elk as i did not have this problem for 6+ months when it was hooked to pc.
Anyone seen this before.......any suggestions (i probably need to update elk firmware and check latest insteon m1sxp firmware)...but am i missing something else?
Thanks!
Thanks!
