H/T/S Sensor on the Master Hub - Jumper on or off?
ksdehoff
Hello:
I'm confused from the forum whether or not I need to enable or disable the onboard voltage regulator if I am powering my Temp/Humidity/Solar sensor from the 6 Channel hub. Can anyone clarify - does injected power count as 'external'?
Ken
ericvic
Ken,
You need to have the jumper in place if you want the Humidity/Temp/Solar device to use the external power provided by the Master Hub. Yes injected power is external power, parasitic power is the power the device "steals" from the data line.
Eric
