Would light switches not show on the ZIM itself?
Light switches would show up on the ZIM itself.
I have two other cables connected in the ports next to the ZIM but they both disappear into the wall and I do not know what they serve.
Do you see any outlets nearby to the panel?
Take a picture of the light switch and post it here and or take a picture of the light switch with the cover removed and post it here.
To manage the lights you will need to look at the PC Access configuration.
In the 1990's extended my CM11A from second floor attic down to the basement fuse panel...old owners of said OP2 panel might have done the same with their TW-523 (X10 interface). I have extended mine about 25 feet from the OP2 panel (and UPB PIM).
Coming back to this thread as I am about to start a project to clean all my automation installation up.
I have UPB switches that I managed to get working again, and can be switched on/off with the Touchscreen 5.7e and the Myro:Home app. I then had to replace the Comcast Xfi modem, and as a result, had to reconfigure my Unifi network, HAI OMNI panel IP address etc. The lights no longer work from the touchscreen OR from the controller attached directly to the panel.
Today I installed a Homeseer Troller hub as I want to use that to slowly add more pieces to my automation set-up that don't need to go through the HAI panel. I installed the HAI plugin for Homeseer and it pulls in all the information from the panel BUT the lights don't work from there either.
What are my options for working out why the lights can no longer be set using HAI? The UPB PIM is plugged in and has a flashing green light for status. I tried using the console to go to the unit, then put the switch into Discover mode, then try to get to config the unit from the controller, however, it just shows "STARTING" and never does anything. I am guessing that it just cannot detect the switch.
On a slightly different topic. Does anyone know why I don't see the HAI panel as a client on my network? I can look at my Unifi dashboard and see all my clients, including my two HAI touchscreens but not the actual HAI panel. I set the IP address, subnet etc. via the controller. It's obviously connected fine, I can ping the IP address and the touchscreens communicate with it. Just have no idea why I don't see it as a device.
Appreciate the assistance.
