ingeborgdot said:
Ok, what kind of a system could I get if you would tell me? I will need 6 light switch dimmers, 1 light switch dimmer for low voltage lights, 1 appliance module to run my curtain motor, 3 light modules. I will also need a controller. Not on a computer but one that will be by my side. I have one plugged in right now. Set up something for me if you were getting something. I would greatly appreciate your expertise. Thanks.
First off, ditch the low voltage lighting set, or at the very least isolate it from the powerline with a filter. The power supplies for those and compact fluorescent bulbs are notorious for putting all kinds of noise on the powerline that will interfere with automation gear.
Second, unplug and put away that Maxi controller. For some reason, they tend to interfere with powerline signals from other devices.
Third, install another filter between your AC line and your home theater electronics. Lots of high-end home theater equipment either introduces noise on the powerline or draws down powerline communications signals.
Next, get one of the Insteon dimmer switch starter kits, two SwitchLinc V2 LED Color Kits and a black sharpie marker. Replace your two most uncooperative dimmer switches with the SwitchLinc v2s (after first installing the Blue light bars from the color kits and going over the bottom light insert [lit when switch is at 0%] with the sharpie).
Next, add more SwitchLinc v2s and Color Change Kits to finish the changeover.
Finally, install and set up your five scenes on your ControLinc, including brightness levels and fade rates.
Now you can sit back and enjoy the movie!
Tom
