Like many, I've had to migrate off the OmniPro II platform, sadly, due to lack of support, parts, etc. and also like many I've moved (or am in the process of moving) to the Elk M1 Gold platform. Except I'm not really - because I have SO much that is built around the OmniPro II, most notably touchscreens running Myro:home that simply cannot be easily (from a UI user-acceptance POV) replaced.
Anyway, the current state is that Elk is my security system and HAI is my automation system - which works fine for 99% of things, except my automation rules knowing when things are armed or not. I've partially solved this by setting up a relay as follows:
I'm having trouble properly understanding the OPII relay outputs. Historically I've gotten them to work through trial-and-error more than understanding, and I currently have a bunch of OPII outputs feeding into ELK912 relays, so I understand the basic premise that the HAI outputs are voltage On/Off. I'm trying to in this case use the OPII outputs without the need for an additional relay, which I don't think I'd need for my intended purpose (i.e., I'm only signaling, not actually switching anything on/off).
I thought I could connect an OPII output to an Elk input but that's not working. The OPII output turns voltage On/Off, so I get that part, but the Elk input is showing a constant 13VDC, so switching voltage On/Off into it doesn't do anything. The Elk input setting options are: "0 = EOL Hardwire/Wireless, 1 = Normally Closed, 2 = Normally Open" I've tried switching between NC and NO with no effect, and I would think that the EOL wireless setting wouldn't apply.
The above detail outlines my whole thinking process, but the TL;DR is this: I want a way for the OPII to communicate to the Elk, "Hey, I'm armed/disarmed."
I'd be grateful for any nudge to improve my understanding of how to do this and why it isn't working as I think it should/would.
Cheers,
Jcd
- I have a relay output of the Elk connected to a zone input of the OPII such that when the Elk is armed the OPII knows and can set a flag accordingly, which is then used in automation events.
Cheers,
Jcd
