clsanchez77
Hey all -
I am starting to think about building an HA system for my house. I am not new to the idea, but all my past projects were X-10 so I am a little behind the times and could sure use some guidance.
FIrst off, I have to settle on a technology. I had researched UPB to death because I had planned on putting in a HAI Omni system in new construction. However three kids and an economic crash later, I had to sell my lot and bought a house instead. Now I will be paying cash for the system and building it up over time. This means I need something scalable. The new Insteon standards seem to work well, but the newer items seem to be Z-Wave. So I am torn between the three. I am an engineer so my plan is to design this thing until my head explodes and then start actually working on it when my wife (also an engineer) starts withholding,,. Here is what I am looking to do in order of preference:
Controller - My preference is for a good hardware controller that has a good iPhone App/interface. Now I have looked into Indigo for Apple and would not throw that out, but it would be least preferred. Nothing that requires a PC. Definitely remote access through broadband. I am familiar with availabilities for Insteon and UPB but no experience. Am completely in the dark about Z-Wave Controllers.
HVAC Controls - Currently I have two 1-stage A/C's; 1 up and 1 down. I would like to monitor and control two thermostats and the thermostats should use remote temp sensors. Future plan is to replace this with a single 2-stage system and break it into multiple zones. Now only do I want to monitor all the zone thermostats, but I would like to be able to break the 2nd stage cool and the 2nd stage heat signal lines using a low voltage controller based on outdoor weather and/or indoor humidity (New Orleans) and/or occupancy. The thermostats are available on all 3 standards but the UPB is far more expensive. Also I am only aware of the low voltage controllers on Insteon.
Bathrooms - I would like to control my bath vents from humidity sensors, heat based on occupancy and/or schedule and temperature and activate a hot water circulation pump based on occupancy and/or sensor. I would likely put a box in the ceiling for the motion sensor and relays, and then use a multi-controller in the wall for manual control.
Fresh Air Intake - Would like to open a fresh air intake into the A/C based on outdoor weather (temp & humidity) or if a bath vent is activated. I would like to be able to manually override this to either open or close.
Lighting Controls - Self explanatory. About 70 different lights & lamps, indoor and out. Would use scene controls to simplify use. Outdoor lights controlled by sunset/timer. Indoor lamps on schedule.
Ceiling Fans - Not really looking to automate but would like to be able to remotely control all of them. I saw where Insteon has a new fan controller, supports light, 3 fan speeds and fan off. Have not seen this with UPB or Z-Wave.
A/V Controls - I am not really looking to control my family room A/V, because I would be in the family room already so I would just use the remote. What I want to be able to do though is control the 2nd zone on my Yamaha Receiver, which I plan to use for stereo outside and in the garage. Being able to turn the whole system off remotely would be a bonus. I also do not need to tie my remote into home control, as I will have iPhone access.
Door Locks Monitor & Control - I have five exterior doors on my house. It would be nice to verify through my system that they are locked and be able to lock them remotely. The only systems I have seen are Z-Wave and while they can be commanded via Insteon, there does not seem to be a solution to have them report status to Insteon. I saw where another forum member used a proximity sensor to overcome this. Very clever. I would rather not remove my door jamb trims for this.
Garage Door Monitor & Control - Same as front door and I saw an Insteon kit for this online, but have not seen anything on the other formats.
Security System - I already have a hardwired security system that covers all of my security needs. It is a very basic system. But it would be nice to be able to monitor the status of the system and even better to have an alarm contact me via broadband while the alarm system occupies the phone.
I am sure there are some other little things I missed, but is a good overall view of what I want. I would love to hear some input on your experiences with the various systems.
Chris
- Remote iPhone Controllable
- Hardware Controller & Mac Laptop Accessible/Compatible
- HVAC Control for three thermostats/zones (maybe five)
- Humidity Monitoring & Response (Bathrooms)
- Outdoor Weather Monitoring & Fresh Air Intake Control
- Lighting Control (70 at full build out)
- Ceiling Fan Control (5 fans with light and speed control)
- Limited Home A/V Control
- Door Lock Monitoring & Controls (Appear to be limited to Z-Wave)
- Garage Door Monitoring & Control
- Determine status of security system
Chris
