Time for part 2 of this mega poll
Which hardware controller do you primarily rely on?
Please keep in mind that you should only vote for one of the hardware controllers, if you programmed it to automatically do some tasks. If you are using your controller as a simple I/O interface with a PC, then it would fall under 'PC based solution'.
If you use a combination of a PC and/or several hardware controllers, then vote for the hardware controller which does the most automated tasks.
I also didn't add an option "None of the above", so people can post their controller in this thread. I will add their choice to the list, then you will be able to vote for it (instead of wasting the vote on 'none').
