I've been a member of the Homeseer message board since 2005 when I was researching home automation systems. I ended up going with CQC and didn't use the HS site for a long time. Recently I started trying to contribute on that site.
Today there was a thread started by a person trying to consider Homeseer vs. Control4. I normally try not to bad mouth HS or push CQC or other systems on that forum, I thought this was a situation where I would point out a potential issue with Homeseer. I posted a reply that basically said that one issue a potential HS user needs to be aware of is how they handle their plugins. Specifically the fact that they tend to be closed so that only the creator can modify the plugin. So there are plenty of examples on the HS forums where users started using a plugin only to have the creator stop supporting the plugin for whatever reason. This leaves the user in a hard spot and many times the user has to start using another plugin (and potentially paying again) that is currently being supported.
I went on to say that no automation system is perfect including the competition, and that a potential purchaser should research all the potential systems out there and make an informed decision. I mentioned other potential software systems like CQC, Elvie, and Premise. I did not try to say one was better than the other or even try to give pros/cons of other systems or link to other systems. They were only mentioned by name.
Anyway, I find my original post removed without any notice or warning from the Admins.
So I guess Homeseer actively censors their user forum. It's unfortunate to see.
Anyway, I just wanted to vent a little. Obviously I cannot vent on HS forum since it will only be removed as well.
EDIT - just an update - my original post suddenly has reappeared. I guess it was reinstated by the admins for whatever reason. Just to be clear - the wording of my original post was never changed by the admins. But deleting a post completely is a form of censorship IMHO which is why I used that terminology.
Of course now all the HS users think I'm some guy with an ax to grind with HS because I've accused the admins of censorship, but with the post reinstated, it looks like I'm crazy. Oh well.....
