The process is pretty similiar for HS 2.
I just went though this when testing the install for something I was sending in to be put in the updater.
You could download the zip files and then take them with you.
You would also want to take a copy of the last_update.txt file.
Here is an example using the Touchpad plugin.
1. Close HomeSeer
2. Place the files in this folder: HomeSeer\updates2\zips
3. In the folder: HomeSeer\updates2
there is a file named last_update.txt
Look in the file for the line that describes the plugins/scripts you want to install.
In the case of Touchpad it looks like this:
TouchPad Interface, hspi_touchpad.ocx, ,2.0.0.21, 7, 1, homeseer.com,/updates2, TouchPad_2-0-0-21.zip, 4, Free, HomeSeer Tech, N/A, Plug-In.gif, TouchPad.htm,,
4. Copy that line into a new txt file and name it: pending.txt
5. Start HomeSeer
At this point it will proceed to install all the updates that are in the pending file.
Rupp,
There shouldn't be a problem with the licenses.
On the Interfaces tab under setup you can click on Manual rather than Online.
When you click Manual you get a message on how to activate the plugin for computers that don't have access to the internet.
