Hi,
I have 2 questions. I'd like to automate my outdoor water setup. I live in the UK but still want my irrigation system to work (although it rains quite a lot anyway!).
At the moment I have one of those plugin timers which shuts on/off my irrigation once a day. It is similar to this.
Now what I'd like to do is two things. First, I'd like to know of some reasonably cheap electronically controlled water valves for the water control, they need to handle mains water pressure and will be operated daily for about an hour. I'm looking really for 12v or 24v. It'd be good if they had the correct size inputs/outputs (ie, so I can screw on hozelock fittings). I've also seen multi-channel valves before, ie, prebuilt with one input and say 4 outputs. That'd be acceptable.
I'm also looking for a small pump/filter I could drop into the bottom of my waterbutt to pump water into my pond. I will be installing float sensors in the pond and waterbutt so I can see how much water is in both, and refill the pond if needed. So a small pump powerful enough for that would be good.
As always
I'm looking for stuff in the UK, links are appriciated, sorry for all the questions,
Ben
As always
Ben
