upstatemike
I am having a problem with stray X-10 signals from outside my house. I often get a long series of B9, B Bright, signals with 20 to 50 transmissions in the string. I also sometimes get long stings of A10, A ON, A10, A OFF, signals as well. These go on long enough to trash any legitimate signal I might be trying to send at that time. I can't use a traditional X-10 blocker because the neutral wire from the meter to my breaker panel is too thick. I can't really replace the wire because it is a long run from the garage where the meter is to the main breaker panel in the basement. It would just cost too much to replace that run! I also think the long run is the reason such a heavy gauge was used and I probably should not downsize it anyway.
Anybody know another way I can attack this problem?
