Jim Doolittle
OK. Getting ready to do some wiring and need an idea of where best to locate a one wire humidity sensor. My TEMP08 plug-in for HomeSeer will tell a UPB plug-in to control an exhaust fan using a UPB UFR based upon humidity.
I need to go from 2nd floor to basement where my TEMP08 is. I am working with wires near wall switch so I could go up and then back down but that would be difficult even though I did leave a string for pulling wire (not much room in attic).
Another alternative would be on the wall near where the shower is (opposite wall switch). I already have a portion of the wall removed and have easy access to basement from there.
The real key is to place the sensor where it will best represent the overall humidity in the room and not look obstrusive. So, the other part of my question is what kind of housing should I use? Whote or ivory would be preferrable. The sensor is on a 2"X2" board with RJ12 (?) connectors.
