Humidity Sensor...
KBevo
Eric, I have your combo Temp, Humidity, Solar sensor. I havent gotten a reading from the Humidity sensor since 9/6. The Temp & solar seem fine and report every poll cycle. Any reason you can think of that the humidity circuit has just stopped reporting?
Gary
ericvic
Gary,
Do you get no reading at all or do the readings not seem correct? If you are not getting any readings at all then I would check the configuration of your software because if you are getting solar readings then the 1-Wire chip is not dead (the humidity and solar use the same 1-Wire chip).
Eric
KBevo
ericvic said:
...if you are getting solar readings then the 1-Wire chip is not dead (the humidity and solar use the same 1-Wire chip)
Yeah, I thought so. No, I'm not getting any Humidity readings at all. I did notice that the sensor serial number for both the solar and humidity are the same. I am getting the sensor just fine, just no humidity. I will check with Michael on the software.
Gary
