I installed our RCS TR40 thermostat over the weekend. This was a retrofit install, so I installed the control unit in the garage next to the furnace (no freezing concerns here in the Pacific Northwest), and used the existing thermostat wiring to connect the control unit to the wall display unit. The RS485 connection was made with standard CAT5 cable, from a closet in which our automation PC is located, to the crawl space, and up to the garage. Worked out pretty nicely. I used a couple of barrier strips and a Radio Shack project box to splice into the existing thermostat wiring in a clean way.
Thermostat works great! Right now, automation-wise, I'm using it mainly as an inside temperature sensor, and also shooting outside temperature to the thermostat for display on the wall display unit. I keep the backlighting on all the time -- the display is really nice. We don't have AC (again, that Pacific Northwest thing), and keep our heating at a set temp all the time (I work out of the home, so someone's around 24/7). But, it will be nice to turn down the temp when we make a yearly trek for a month down to the southwest, and be able to turn the temp back up the morning that we're set to arrive back in town.
My only "wishlist" is that I wish that when you send messages to the display, that they would automatically be displayed, instead of requiring the user to press a messages button. That way I could use the thermostat as a caller ID display as well. As it is, this doesn't work, as someone would have to go to the thermostat, and press a button, which isn't that convenient.
So, overall, 9 out of 10 stars!
