Trying to understand why Insteon lights turn themselves off after turning them on manually when Elk M1XSP Serial interface is connected to the Insteon 2414S Powerlinc?
I've been using Insteon & Elk for some time in my own home, but have recently been working with PowerHome to create links & groups native in the Insteon switches and KeypadLincs. All the Insteon groups are working as expected until I plug the 2414S back into the M1XSP.
Once these are connected, lights can be controlled fine using the Elk but often when I manually turn on a light at the switch it will fade up and then immedietly fade back off. Usually if I turn the light on manually 3 times, it will finally stay on. Same with scenes initiated from a Keypadlinc button... all the expected lights will ramp up to the desired levels, and then return to off or the lowest LED?
Originally used "elkinsteon.exe" from Powerhome to populate the Insteon devices in the M1XSP and everything works fine until I create additional links between switches. The problem seems to be worse on switches/buttons that have many links (switches that just have a few simple links seem to usually work).
It's got to be the 2414S & M1XSP/M1 that aren't playing well together. As soon as I unplug the 2414S from the serial expander (or unplug the 2414S from the wall) all the links/groups/scenes programmed into the switches work perfectly.
I remember someonw else reporting similar problems on one of the message boards a few weeks ago, but he didn't receive any advice and now I can't find the post to see if there's been any follow-up.
Any advice greatly appreciated...
Paul
Paul
