Okay... I know Insteon is much-maligned at this point... and I really appreciate the posts from those with EXPERIENCE in the alternative solutions (UPB and Z-Wave, specifically, as similarly-timed introductsions to a similar market). Those posts point out that as much as may be wrong with Insteon there's simply goods and bads to all the various solutions out there.. which is so true of most things in life, of course.
I intro this way so that I might avoid any of the "you need to dump Insteon and go with a true-RF-with-integrated-hard-wiring-and-direct-ESP-ready-solution that'll be perfect next decade" (though that DOES sound cool).
Here's the deal: after juggling the SignaLinc locations a bit, I have them in a location that produces 100% reliable communication 100% of the time between Insteon switches. Did I say 100%? I meant to. 100%. Might as well be hard-wired, they're so fast and reliable. All 50 devices. 100%. Don't like it? Don't believe me? Come visit; the weather's great here.
I've replaced the switches that died when there were power-surges. I've replaced a couple of the ones that flickered (found another recently). I've replaced one of the flickering KeypadLincs (the button lights flicker when other devices send signals), so I know I can replace the other dozen eventually.
Yeah... there are reliability and firmware issues.
h34r:
I've been messing with HomeSeer and MainLobby and now HouseLinc and PowerHome. I have Elk working beautifully - though for basic load on/off stuff mostly. The software progress is slow, but it is evident as progress.
Yeah... the software development is slow.
Anyway... why the post?
PLC consistency.
I've got three PLCs - one to the Elk, one to the HA PC (interchangeably used for HS/ML/PH/HL), and one to my PC for testing and such. The one at the HA PC doesn't pick up the devices as consistently and reliably in HL as on my PC. I've found that if I move from outlet to outlet this changes. My guess is that there are lots of retransmissions between switches to create the reliability I've seen and the PLC is not doing this... so I'm seeing inconsistencies.
I added another SignaLinc at the HA outlet and plugged the PLC directly into it. Is this bad? It didn't help much.
I'm about ready to run another feed to the location from the panel - which I expect will work great - but I'd much prefer an RF-based fix.
Help?
PLC consistency.
Help?
