I would like to get some cameras going, and I'm having a hard time deciding on the topology. To me, logically, IP cameras seem like the best option, as they do all their compression internally, and can "stand alone"... considering the resources the PVR cards require, I'm not sure I'd want it on either my Homeseer machine or my HTPC, but I'm not too keen on adding yet another 24x7 PC in my home. While a 24x7 PC would be needed to record the output, simply capturing a stream, and even doing motion detection on an available stream, is a much more light duty task than doing the actual encoding of multiple cameras. Plus, it seems I often see threads of configuration hassles. I like the autonomous nature of an IP camera who's output can be viewed from anywhere, even if the "recording" pc is down. And of course, a camera can be added at any time - no worry of outgrowing the number of inputs on a PVR card.
Despite the advantages I see of IP based cameras, it seems like most people are going with conventional cameras and a PVR card (or in some cases, a dedicated PVR device). Some of the reasons are obvious to me: much wider selection of cameras, and probably generally higher camera quality, as well as lower per camera cost for a given quality. Is there anything else I'm missing? I'd really be interested in hearing the opinions of those who have more knowledge on the subject than I (which is probably most of you). Another thing I'm considering is simply waiting for a while for IP cameras to mature a little (and therefore become cheaper, with a wider selection and higher quality). Any thoughts on the pace of that market?
