Hi -
Before I order all my switches, I wanted to make sure I'm clear on Relays vs Dimmers.
Do I need to use Relays in conjunction with a Dimmer in 2 or 3 way loads where the load can be dimmed? Or, is a Relay only needed for non-dimming loads?
scenario #1
- One switch controls one dimmable light
- I would install a Dimmer
scenario #2
- One switch controls a non-dimmable load (for example, a CFL or a bathroom fan)
- I would install a Relay
scenario #3
- Two switches control a dimmable (load of) lights
- Do I use one Dimmer plus one Relay, or can I use 2 Dimmers? I think I want two dimmers so I can dim from either location...
- Related, can I use a "standard" (non automated, non jetstream) switch in conjunction with a Dimmer in a 2 or 3 load connection?
Chris
scenario #1
scenario #2
scenario #3
Chris
