Kodicom Diginet KCM4400R
levwinski
Hello
Over the past couple of years an electrician/security guy has installed KMC4400R based systems at my home and my workplace. I am starting to take an interest myself as he takes forever to turn up when I have a problem.
From what I understand, these boards are all fakes when used anything other than a commercial build PC, that usually come with a ver. 4.11 (unofficial release). However, from the other threads on this board, I understand that I should be ok using ver. 4.13 patch 7 as long as I use an intel chipset and ATI/Nvidia graphics card. If this is not so, please advise.
My actual confusion is this - everything I can find regarding KMC4400R suggests that it is 16 channel - however, he has installed it as if it is only 8. At my home, I have 16 cameras but he has attached two of the boards into one PC. At work I have 32, so he has built two PCs each containing two boards.
The 16 cameras in each PC are attached via a parallel port. The port has a ribbon that at the board end is split into 4 groups of 4x2 pins.
Imagine each line as a board, and the pins are connected to the two cards as follows:
1,2,3,4..........9,10,11,12................
..........5,6,7,8 ............. 13,14,15,16
I tried taking the two bottom sets and inserting them into the empty slots in the top card and rebooted the PC. I did not make any software setting changes. I only got 8 images. Cameras 5,6,7,8 and 13,14,15,16 were just blue squares.
I was wondering if anybody would be kind enough to shed some light on this for me.
