LCD Driver and 20x4 Display
Shannon
The Example Java code at the top says :
package com.electronicvisions.onewire.devices;
What is the Java Compiler you used to compile this is = electronicvisions ?
I would like to do it in Visual Basic 6, and I dont know much about Java.
Can You Help ?
Thanks.
END. B)
ericvic
Shannon,
You need to remove the package statement, I will correct that and get a new sample posted. I use eclipse and JDK1.5 to compile all my Java code.
I know very little about VB so I can't help you with that one.
Eric
Shannon
I Can't Compile the 2 Java Files.....
Using DOS, How would you compile the 2 files ?
and a .DLL to be put in this directory : com.dalsemi.onewire
IE :
import com.dalsemi.onewire.OneWireAccessProvider;
import import com.dalsemi.onewire.OneWireAccessProvider;
import com.dalsemi.onewire.OneWireException;
import com.dalsemi.onewire.adapter.DSPortAdapter;
import com.dalsemi.onewire.adapter.OneWireIOException;
.OneWireException;
END.
ericvic
Shannon,
You need to download and install the 1-Wire drivers from Dallas if you haven't already.
As for compiling from the command prompt I'm not going to be much help there. I never compile directly from the command prompt, I use eclipse IDE. I do know that you use javac (the Java compiler) that comes in the JDK from Sun but I don't have any idea what the inputs are.
Sorry I was not much help.
Eric
