sda
I'm trying to put together a sample circuit with an LM311 to make sure I understand how it works.
From what I do understand, which seems to be wrong, is that pin 7 is an open collector.
When pin 2 voltage (input+) is less than pin 3 voltage (input-), conditions are met and pin 1 (emit out) is connected to pin 7 (col out),
in this case ground, and the LED should turn on. It doesn't. But if I connect pin 2 directly to ground, 0V, the LED will turn on.
What am I doing wrong? Probably everything!
