Scott
I built my home in 2002 and unwisely went with OnQ HMS-1050 (clone of HAI OmniPro II) rather than HAI OmniPro II.
OnQ exited the business shortly after and I foolishly did not upgrade my board to OmniPro II right away...
I used PC Access and WebLink II to control my OnQ for years and then an electrical storm knocked it out. Dead board.
I scored an HAI OmniPro II (firmware 4.0B) and have been trying to drop-in replace the OnQ, but... well I am struggling.
Can I shortcut the programming by trying to restore by backed up PC Access settings from the old OnQ and get it mostly right, then fine tine from there?
I have been able to boot the new board and 3 of the 4 consoles come online, and the 4th intermittently (I think that is a fault/short in a connector at the console, as I have good Fox&Hound signal all the way from the main board to the console on all for connections).
I am dismayed at the completely empty of any programming new board though... I should have expected that.
What is the best way to get the security functions mostly working again?
Should I connect with PC Access first?
Is it worth trying to restore the old PCA file which had loads of programming already loaded (nearly 20 years of use)...
I am hoping to switch to Haiku once the system is online, as we are a mostly Macintosh household; though I do have a few PCs lying around for specific tasks like PC Access and WebLink II.
I am most concerned about getting the door and window alarms back online, and can work with thermostats and smoke/fire later...
The thermostats are holding their own programming though the clock drift without the central system is really annoying.
New board:
Leviton OmniPro II v4.0B English
I am hoping most of the OnQ expansion boards will just work with this.
The OnQ consoles seem to already.
The old system:
Main Board 10A01-7 Rev F13 (HAI OnQ 1.9 chip)
Hardware Expander 10A06-1 Rev A (adds 16 zones)
Serial Interface 10A17-1 REv A
Expansion Enclosure 17A01-2 Rev A (adds 16 more zones, and 8 other things)
I suspect I will have to replace a couple of window sensors as the old unit was showing trouble with those before it died.
I am hoping to change my X-10 lighting controls and alarm set LEDs with UPB or a mix of X10 and UPB.
New board:
The old system:
