How come as I'm moving around the forums, e.g. reading threads, hitting the back button, using the breadcrumb links at the top of pages, I keep getting logged out? I have to login many times during a "session". I have cookies enabled and everything.
Do you have a load balancing router with multiple internet connections? If the forum software sees your IP change while in a session, it will close the session and force you to log in again.
Ok, that would explain it when I read CT from work. Damn [email protected] expect me to be working, not reading.
I'll check to see if it happens from home.
