Testing today if you can get an installer code via a serial connection to PC Access. You can with a PC and serial connection to your panel.
1 - Windows PC and a serial cable to your Omni Panel
2 - PC Access
3 - Configure PC Access to serial defaults
4 - connect to your panel
5 - download configuration to your PC
6 - you will see the installer code under Misc as installer code.
You cannot do this with an Ethernet connection as you need the keys to configure the network connection and you cannot see the keys on the console unless you enter the installer code.
I tested this today with a 3 wire serial connection to one of the serial ports on the Omnipro 2 panel that I leave connected to one server on the rack running Windows 2016 server.
2 - PC Access
