K... the Insteon config for M1 is not pretty... but it works... kinda. <_<
Clearly, having to re-enroll each switch manually starting at number on if there is any issue is NOT ideal. And enrolling three or four at a time is out of the question because when one doesn't enroll as expected, I have to default the XSP and start over unless I want the order spread all over the place.
The one part that's got me a bit confused is that the M1 is still transmitting the X10 codes for each light as if they were still there. Yes, it's controlling the Insteon switch through Insteon ('cause A1 does not control that light <_< ), but A1 on/off is still being transmitted to the powerline as well.
Can this be stopped?
Also, is it possible to see what lights are enrolled or not? I'm enrolling one light at a time, but if one doesn't seem to work yet the M1 thinks it did (gawd knows why), then the M1 slots the same light into the next slot as well. Not ideal. :unsure:
I've got about 50 Insteon lights. I can't get six of them to enroll and work because of the above issues. I keep having to start over when one doesn't "take" right. I can't imagine how long it'll take at this rate to get all 50 in.
I know about the issues that HomeSeer and others are having due to the SDM problems, but I don't see a SmartHome SDM involved here. What's the time-frame to get Insteon to a more usable state?
